StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel
Quicklinx: 87PMWS00 Mfr#: PANELHU24
Ports: 24 ports
22 in stock
£31.10 ex VAT
£37.32 inc VAT
Organize up to 24 Cat5e patch cables using only 0.5U of rack space. The PANELHU24 Rack Mount Cat5e patch panel condenses 24 ports into a 0.5U panel, making it an ideal solution for smaller installations.
Color coded for both T568A and T568B wiring, this network patch panel provides the perfect solution for any voice or LAN application and offers dual type IDC termination. For convenience, the port numbers are clearly marked on the front of each RJ45 port, offering a quick and easy way to identify cable runs.
StarTech.com 24 Port 0.5U Cat5e Patch Panel - patch panel
Patch panel - CAT 5e
Port Qty
24 ports
P/N: 2POSTRACK42, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RK1219SIDEM, RK1219WALHM, RK1219WALLOH, RK1236BKF, RK219WALVO, RK2536BKF, RK419WALVO, RK419WALVS, RK419WALVSGB, RK619WALL, RK619WALLGB, RK619WALLOH, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK960CP, RKQMCAB12, RKWOODCAB12
Cabling & Wiring
Port Qty
24 ports
Termination Type
110 type termination
Connector Provided
24 x 110 female
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1236BKF, RK12OD, RK219WALLV, RK219WALVO, RK2236BKF, RK2536BKF, RK319WALLV, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4242BK, RK619WALL, RK619WALLGB, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK960CP, RKQMCAB12, RKWOODCAB12, WALLMOUNT6, WALLMOUNTH1, WALLMOUNTH2, WALLMOUNTH4
Ports: 24 ports
Price Range Ex VAT: 0 - 50
