This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA24 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
- StarTech.com 24in SATA Serial ATA Cable - SATA cable - Serial ATA 150 - SATA (F) to SATA (F) - 2 ft - red - SATA24 - SATA cable - 0.6 m
- SATA cable
- Interface Speed
- Serial ATA 150
- Length
- 0.6 m
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- Red
- Limited lifetime warranty
- Designed For
- P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SATSAS35, 25SATSAS35HD, 2P6G-PCIE-SATA-CARD, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, CFAST2SAT25, PEXM2SAT32N1, PEXSAT32, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATPEX, SATBP125VP, ST521PMINT, USB3SSATAIDE
- Storage Cable Type
- SATA cable
- Interface Speed
- Serial ATA 150
- Length
- 0.6 m
- Red
- Connector
- Designed For
- P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SATSAS35, 25SATSAS35HD, 2P6G-PCIE-SATA-CARD, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, CFAST2SAT25, HSB220SAT25B, PATA2SATA3, PEXM2SAT32N1, PEXSAT32, PEXSATA22I, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATPEX, SATBP125VP, SATSASBAY3BK, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
