Extend Slimline SATA power and data connections by up to 20 inches. The SLSATA20EXT Slimline SATA Extension Cable features one Slimline SATA male connector and one Slimline SATA female connector, allowing you to extend the distance/placement of slim SATA drives within a tower style computer case by 20in - in turn making it easier to position your Slimline capable peripherals (drives etc.) as needed.
Constructed of only top quality materials and designed for optimum performance and reliability the SLSATA20EXT supports full SATA 3.0 bandwidth (up to 6 Gbps) when used with SATA 3.0 compliant drives.
- StarTech.com Slimline SATA Extension Cable - SATA extension cable - 50.8 cm
- Interface Speed
- Serial ATA 150/300
- Length
- 50.8 cm
- Connector
- 13 pin Slimline Serial ATA - male
- Connector (Second End)
- 13 pin Slimline Serial ATA - female
- Red
- Limited lifetime warranty
- Storage Cable Type
- Interface Speed
- Length
- 50.8 cm
- Red
- Connector
- RoHS
