StarTech.com 20in Right Angle Slimline SATA to SATA w/ LP4 Power Cable
Quicklinx: 6PFRWS00 Mfr#: SLSATAF20RA
Install Slimline drives into systems with standard SATA controllers. The SLSATAF20RA Right-Angle Slimline SATA to SATA with LP4 Power Cable (20-inch) features a SATA data receptacle and a Molex (LP4) power connection on one end, and a right-angle Slimline Serial ATA receptacle on the other - enabling you to connect a slim SATA drive to a computer motherboard that does not have a Slimline connection available.
Plus, the right-angled Slimline SATA connector allows for connectivity in narrow spaces, enabling installation of the drive as needed within the system case.
Constructed of only top quality materials and designed for optimum performance and reliability the SLSATAF20RA supports full SATA 3.0 bandwidth (up to 6 Gbps) when used with SATA 3.0 compliant drives.
StarTech.com Right Angle Slimline SATA Female to SATA w/ LP4 Power Cable - SATA cable - 50.8 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Length
50.8 cm
Connectors
13 pin Slimline Serial ATA - female
Connectors (Second End)
7 pin Serial ATA - female , 4 pin internal power (12V) - male
Red
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
26
Length
50.8 cm
Red
Connectors
RoHS
6PFR StarTech.com SATA to LP4 Power Cable Adapter In Stock £5.24
6PFR StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power In Stock £3.35
6PFR StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 In Stock £5.15
