Add an un-managed, 20-slot media converter chassis to your rack or cabinet. The ETCHS2U 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Media Converters lets you add an un-managed, 20-slot media converter chassis to your rack or cabinet to provide central power and cooling.
The media converter rack includes a single 200W power supply to centrally power all 20 slots, with an additional slot to add a redundant power supply for maximum up-time. It also includes two cooling fans (one per side) to help extend the life of your media converters.
A perfect accessory to the StarTech.com ET series 2 converters, the 2U chassis is designed so that all critical components (Power, Fans and Media Converter Cards) are hot swappable to avoid network disruption.
- StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converter - modular expansion base
- Modular expansion base
- Form Factor
- Rack-mountable - 2U
- Localisation
- North America, United Kingdom, Europe
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 43.8 cm x 30.3 cm x 8.8 cm
- 5 kg
- 2-year warranty
- Height (Rack Units)
- 2U
- Installed Modules Qty (Max)
- 0 (20)
- 43.8 cm
- 30.3 cm
- 8.8 cm
- 5 kg
- Enclosure Colour
- Black
- Localisation
- Form Factor
- Rack-mountable
- Connectivity Technology
- Wired
- Expansion Slots
- 20 (total) / 20 (free) x expansion slot
- MTBF
- 65,000 hours
- UL, FCC, RoHS
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Voltage Required
- 60 Watt
- Power Provided
- 200 Watt
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 90% (non-condensing)
StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST 2 km | In Stock | £57.64 |
StarTech.com 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC 20km | In Stock | £239.09 |
StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m | In Stock | £127.49 |
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £115.23 |
StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps | In Stock | £305.47 |
StarTech.com 10/100 Mbps Single Mode Fiber Media Converter SC 30 km | In Stock | £124.81 |
StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converter | In Stock | £483.18 |
StarTech.com Redundant 200W Media Converter Chassis Power Supply Module for ETCHS2U | In Stock | £252.55 |
