StarTech.com 20 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 7NYMWS00 Mfr#: HDMIMM20HS
Length: 6.1m
10 in stock
£31.80 ex VAT
£38.16 inc VAT
Create Ultra HD connections between your HDMI -enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM20HS 20-foot High Speed HDMI Cable with Ethernet supports the advanced capabilities of the High-Definition Multimedia Interface, including Ethernet data inter-connectivity with compatible HDMI-enabled products, and is fully backward compatible with older HDMI-capable devices.
The cable features gold-plated HDMI (male) connectors which help to ensure a high quality digital connection capable of transmitting high-definition video and multi-channel audio between devices such as Blu-Ray Disc players, HDTVs, DVD Players, DVRs, stereo receivers and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
All StarTech.com High Speed HDMI Cables are expertly designed and constructed of top quality materials to deliver dependable high-definition performance.
StarTech.com 20 ft High Speed HDMI Cable w/ Ethernet - Ultra HD 4k x 2k - HDMI with Ethernet cable - 6.1 m
Cable
American Wire Gauge (AWG)
26
Length
6.1 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
26
Jacket Material
PVC
Length
6.1 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
Length: 6.1m
Price Range Ex VAT: 0 - 50
