Provide a high-speed, crystal-clear connection to your DVI digital devices, with a long 20-foot cable. The DVIDSMM20 DVI-D Single Link cable features 2 male DVI (19-pin) connectors and offers 20 feet in cable length, making it perfect for longer connections between your desktop or laptop computer and a DVI-D monitor or projector.
The 20ft DVI-D male to male cable supports resolutions of up to 1920x1200 and transmission rates of up to 4.95 Gbits/sec, and is fully compliant with DVI DDWG standards.
- StarTech.com 20 ft DVI-D Single Link Cable - M/M - DVI cable - 6.1 m
- DVI cable - single link
- Length
- 6.1 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- Plug and Play
- Black
- Limited lifetime warranty
- Designed For
- P/N: PEX2PCI4GB, PEX2PCI4, ST122DVIGB, ST124DVI, ST122DVI
- DVI cable
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Single link
- Length
- 6.1 m
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- Plug and Play
- Designed For
- StarTech.com 2 Port DVI-I Video Splitter - Digital and Analog, 4 Port DVI-I Video Splitter - Digital and Analog, PCI Express to 4 Slot PCI Expansion System
