Provides a high-speed, crystal-clear connection to your DVI digital devices, with a long 20-foot cable. The DVIDDMM20 20ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and offers 20 feet in cable length, making it perfect for longer connections between your desktop or laptop computer and a DVI-D monitor or projector.
The 20 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com Dual Link DVI Cable - 20 ft - Male to Male - 2560x1600 - DVI-D Cable - Computer Monitor Cable - DVI Cord - Video Cable (DVIDDMM20) - DVI cable - 6.1 m
DVI cable - dual link
Length
6.1 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2DVID2, DP2VGDVHD, DVI92030202L, HD2DPVGADVI, HDDVIMF8IN, MDP2DVI3, USB2DVIPRO2, USB32DVIEH, USB32HDDVII
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
6.1 m
Connector
24+1 pin digital DVI - male
P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2DVID2, DP2VGDVHD, DVI92030202L, DVIEXTAA6IN, DVISPL1DD, HD2DPVGADVI, HDDVIMF8IN, HDMIDVIMF, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, SV221DVIDD, SV231DD2DUA, SV231DDVDUA, SV431DD2DUA, SV431DDVDUA, USB2DVIE3, USB2DVIPRO2, USB32DVIEH, USB32DVIPRO, USB32HDDVII
