StarTech.com 20 ft DisplayPort Cable with Latches - M/M
Quicklinx: 7NXGWS00 Mfr#: DISPLPORT20L
Length: 6.1m
Hurry, only 2 left in stock!
£31.57 ex VAT
£37.88 inc VAT
The DISPLPORT20L 20ft DisplayPort cable supports a maximum bandwidth of 10.8 Gbps, and is capable of providing higher performance than either HDMI or dual link DVI and supporting next generation multimedia applications with a maximum resolution capability of up to WQXGA (2560×1600).
The cable features small, USB-sized latching connectors, with support for 2-way display connectivity and optional audio support. This 20-foot DisplayPort cable is both HDCP and DPCP capable, ensuring that digitally protected content is displayed properly on the connected display.
StarTech.com 20 ft DisplayPort Cable with Latches - M/M - DisplayPort cable - 6.1 m
DisplayPort cable
Shielded
Latched, molded
Length
6.1 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS, NEC-CMG
P/N: USB32DPPRO
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
26
Plated Connector
Nickel
Latched, molded
Length
6.1 m
Connector
20 pin DisplayPort - male
RoHS, NEC-CMG
P/N: USB32DPPRO
7NXG StarTech.com 25 ft DisplayPort Cable with Latches - M/M In Stock £45.83
7NXG StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.72
7NXG StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
Length: 6.1m
Price Range Ex VAT: 0 - 50
