StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M
Clearance!
Clearance
Last Few Remaining
Quicklinx: 76MXWS00 Mfr#: MXT101MMHQ20
Type: VGA
Length: 6.1m
£9.79 ex VAT
£11.74 inc VAT
This 20ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 6.1 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
6.1 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
UL 2919, RoHS, NEC-CMG
P/N: DP2VGAA, DVI2VGAE, HD2VGAE2, HD2VGAMICRO, MCHD2VGAE2, MDP2VGA2, MNHD2VGAE2, USB32VGAES
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
6.1 m
Connector
76MX StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
76MX StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
76MX StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £6.09
76MX StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
76MX StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £4.72
Type: VGA
Length: 6.1m
Price Range Ex VAT: 0 - 50
