This 20ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 20 ft. (6.1 m) VGA to VGA Cable - HD15 Male to HD15 Male - Coaxial High Resolution - High Quality - VGA Monitor Cable (MXT101MMHQ20) - VGA cable - 6.1 m
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Molded, ferrite bead
- Length
- 6.1 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- UL 2919, RoHS, NEC-CMG
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2VGA, CDP2VGAFC, CDP2VGAUACP, CDP2VGAUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDBP, CDPVGDVHDMDP, DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, DP2VGA3X5, DP2VGAA, HD2DPVGADVI, HDVGADP2HD, MDP2HDVGAW, MDP2VGAAMM2M, MDP2VGAAMM3M, MSTS3MDPUGBK, SV231USBLC
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 6.1 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- Designed For
- P/N: CDP2VGA, CDP2VGAFC, CDP2VGAUACP, CDP2VGAUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDBP, CDPVGDVHDMDP, DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, DP2VGA, DP2VGA2, DP2VGA3, DP2VGA3X5, DP2VGAA, DP2VGDVHD, DVI2VGAE, DVI92030202L, DVIVGAMF, DVIVGAMFBK, HD2DPVGADVI, HD2VGAA2, HD2VGAE2, HD2VGAMICRO, HDVGADP2HD, MCHD2VGAE2, MDP2HDVGA, MDP2HDVGAW, MDP2VGA, MDP2VGA2, MDP2VGAAMM2M, MDP2VGAAMM3M, MDP2VGAW, MNHD2VGAE2, MSTP3MDPUGBK, MSTS3MDPUGBK, SV1631DUSBUK, SV231DDVDUA, SV231USB, SV231USBLC, SV431DDVDUA, SV431USB, USB2VGAE2, USB2VGAE3, USB2VGAPRO2, USB32VGAES, USB32VGAPRO, VGA2VID
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.03 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F | In Stock | £7.06 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F | In Stock | £7.03 |
