Your basket is empty
StarTech.com 20 ft Cat5e Gray Molded RJ45 UTP Cat 5e Patch Cable
Quicklinx: 8CN7WS00 Mfr#: M45PATCH20GR
Length: 6.1m
Colour: Grey
More than 50 in stock
£4.26 ex VAT
£5.11 inc VAT
Standard delivery Delivered within 3-5 working days
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT20GR Cat5e Patch Cable (20 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
StarTech.com 20 ft Gray Cat5e / Cat 5 Molded Patch Cable 20ft - patch cable - 6.1 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568A
Wires per Cable
8 wires
Molded
Length
6.1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568A
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
6.1 m
Grey
Connector
RJ-45 - male
RJ-45 - male
UL
Length: 6.1m
Colour: Grey
Price Range Ex VAT: 0 - 50
