StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention
Quicklinx: 67C9WS00 Mfr#: ICUSB2322X
Type: Serial adapter
Compatibility: PC
Interface: USB
16 in stock
£34.70 ex VAT
£41.64 inc VAT
The ICUSB2322X 2 Port Professional Grade USB Serial Adapter converts a single USB port to two RS232 serial ports allowing you to connect to, monitor and control your serial devices. Rugged metal construction and sturdy wall-mount brackets provide a robust solution for both harsh industrial environments and simple desktop installations. Powered by USB, the device does not require a power outlet for most standard applications. For installations requiring more power through the RS232 ports, the hub supports connection of an external power adapter (not included) to the integrated DC jack or terminal block. Once connected, the adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the ports provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative Serial adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading serial peripherals for USB compatibility.
StarTech.com 2 Port USB to Serial Adapter Hub with COM Retention - serial adapter
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232 x 2
11.3 cm x 8 cm x 2.3 cm
300 g
RS-232
Data Transfer Rate
230 Kbps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
Serial adapter
External
USB
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
230 Kbps
2 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type B
FCC, RoHS
Software Included
Drivers & Utilities
11.3 cm
8 cm
2.3 cm
300 g
67C9 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
67C9 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £14.45
67C9 StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F In Stock £13.61
67C9 StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £34.70
67C9 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.14
Compatibility: PC
Interface: USB
Price Range Ex VAT: 0 - 50
