StarTech.com's Wall Mountable VGA Video Splitter lets you distribute and deliver VGA video from a single video source to two monitors simultaneously - a perfect solution for digital signage applications, retail and tradeshow environments, educational and government facilities, or corporate displays where high quality video is required.
The wall mountable VGA video splitter is very simple to install, letting you locate screens up to 200ft (61m) away from the VGA video source and supports resolutions up to 1600 x 1200.
- StarTech.com 2 Port Wall Mount VGA Video Splitter - video splitter - 2 ports
- Video splitter - 2 ports - cascadable
- Subtype
- VGA
- Ports
- 2 x VGA
- Wall mountable
- 8.6 cm x 11.5 cm x 3.3 cm
- 140 g
- Silver
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- VGA
- Ports
- 2 x VGA
- Max Cascading Depth
- 3
- Max Resolution
- 1920 x 1440 @ 75 Hz
- Max Video Bandwidth
- 250 MHz
- Wall mountable
- Status Indicators
- Power
- 2 x VGA output HD-15 , 1 x VGA input HD-15
- Power Device
- External power adapter
- 1.35 Watt
- Silver
- FCC, RoHS
- Localisation
- United Kingdom
- 8.6 cm
- 11.5 cm
- 3.3 cm
- 140 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 80%
