StarTech.com 2 Port Wall Mount VGA Video Splitter
Quicklinx: 5FQTWS00 Mfr#: ST122WGB
StarTech.com's Wall Mountable VGA Video Splitter lets you distribute and deliver VGA video from a single video source to two monitors simultaneously - a perfect solution for digital signage applications, retail and tradeshow environments, educational and government facilities, or corporate displays where high quality video is required.
The wall mountable VGA video splitter is very simple to install, letting you locate screens up to 200ft (61m) away from the VGA video source and supports resolutions up to 1600 x 1200.
StarTech.com 2 Port Wall Mount VGA Video Splitter - video splitter - 2 ports
Video splitter - 2 ports - cascadable
Subtype
VGA
Ports
2 x VGA
Wall mountable
8.6 cm x 11.5 cm x 3.3 cm
140 g
Silver
United Kingdom
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
Max Cascading Depth
3
Max Resolution
1920 x 1440 @ 75 Hz
Max Video Bandwidth
250 MHz
Wall mountable
Status Indicators
2 x VGA output HD-15 , 1 x VGA input HD-15
External power adapter
1.35 Watt
Silver
FCC, RoHS
United Kingdom
8.6 cm
11.5 cm
3.3 cm
140 g
50 °C
0 - 80%
