Product
StarTech.com 2 Port VGA Video Splitter with Audio - USB Powered
Price Drop!
Last Few Remaining
Price Drop
Quicklinx: 76QFWS00 Mfr#: ST122LEA
14 in stock
£25.73 ex VAT
£30.87 inc VAT
Standard delivery Delivered within 3-5 working days
A compact, USB powered solution for extending a high-resolution VGA signal from a computer between 2 monitors/displays or projectors.
The ST122LEA 2 port VGA video splitter with audio and USB power is the most compact VGA splitter, allowing a computer to simultaneously display VGA video on two monitors from a single source.
Support for resolutions up to 2048x1536 resolution and stereo audio makes this device perfect for classrooms, tradeshows, or any environment requiring high quality video on several displays.
This VGA splitter is able to draw power from your source PC or media player using an available USB port, instead of using a conventional power adapter making it easy to install where power outlets are not available. The splitter also features a built-in booster circuit that allows you to locate VGA monitors up to 200ft away from your system.
StarTech.com 2 Port VGA Video Splitter with Audio - USB Powered - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
Subtype
VGA / audio
Ports
2 x VGA + 2 x audio
USB powered
5.3 cm x 6.8 cm x 2.3 cm
115 g
2 years warranty
Enclosure Type
Desktop
Subtype
VGA / audio
Ports
2 x VGA + 2 x audio
Max Resolution
2048 x 1536 @ 60 Hz
Max Video Bandwidth
300 MHz
USB powered
2 x VGA HD-15 , 2 x audio mini-jack , 1 x VGA HD-15 , 1 x audio mini-jack
DDC-2B, FCC, RoHS, DDC
5.3 cm
6.8 cm
2.3 cm
115 g
70 °C
0 - 95%
76QF StarTech.com 6 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £3.65
76QF StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M In Stock £3.37
76QF StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £3.42
76QF StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable In Stock £3.71
Price Range Ex VAT: 0 - 50
