Your basket is empty
StarTech.com 2 Port VGA Video Splitter - 250 MHz
Customer rating: 5.0* (Write a review)
Quicklinx: 4H1FWS00 Mfr#: ST122LGB
The ST122LGB 2 port VGA video splitter allows a single VGA source to display VGA video onto two monitors simultaneously. Perfect for classrooms, tradeshows, or in-store displays where high quality video on several monitors is needed. The simple plug and play operation makes setup quick and easy so you can be up and running in minutes.
The ST122LGB supports displays with up to 250 MHz of bandwidth, providing brilliant resolutions up to 1920x1440. A built-in booster circuit lets you situate your displays up to 210 ft away from your source.
StarTech.com 2 Port VGA Video Splitter - 250 MHz - video splitter - 2 ports
Video splitter - 2 ports
Subtype
VGA
Ports
2 x VGA
13.1 cm x 6.5 cm x 2.6 cm
220 g
United Kingdom
2 years warranty
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
Max Resolution
1920 x 1440
Max Video Bandwidth
250 MHz
2 x VGA output HD-15 , 1 x VGA input HD-15
External power adapter
FCC
United Kingdom
13.1 cm
6.5 cm
2.6 cm
220 g
4H1F StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.73
Customer reviews
Write a review for the StarTech.com 2 Port VGA Video Splitter - 250 MHz here!
Cables required
Reviewed by Mr Helpful. Review Posted 27/01/2009
Please note, this product requires the following cables:
PC to switchbox - MALE to FEMALE VGA cable
switchbox to device (TFT, Projector, etc) - MALE to MALE VGA cable.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
