StarTech.com 2 Port VGA over Cat5 Video Extender – Transmitter
Quicklinx: 7Y3ZWS00 Mfr#: ST1212T
Type: Extender
£67.25 ex VAT
£80.70 inc VAT
The ST1212T 2-Port VGA over Cat 5 Extender is designed for use with the ST121 VGA over Cat 5 extension series, offering convenient video distribution at distances of up to 500 feet (150 meters) using standard Cat 5 (or better) Ethernet cabling. Comprised of the transmitter unit only, the ST1212T requires one Receiver Unit (ST121R) per display that you are connecting.
For added versatility, the VGA over Cat 5 Repeater (ST121EXT) can be used to extend the distance between the transmitter and receiver by an additional 500 feet (150 meters), for a total extension distance of 1000 feet (300 meters). Similarly, up to 3 repeater units can be used between transmitter and receiver, enabling you to connect monitors at each repeater, while still extending the total distance.
StarTech.com 2 Port VGA over Cat5 Video Extender - Transmitter - video extender
Video extender
External
Max Transfer Distance
150 m
6 cm x 10.2 cm x 2 cm
200 g
Video extender
External
Wired
Max Resolution
1600 x 1200
150 m
Status Indicators
1 x VGA (output) - HD-15 female , 1 x VGA (input) - HD-15 male , 2 x display / video - output - RJ-45 female
FCC, RoHS
External power adapter
6 cm
10.2 cm
2 cm
200 g
0 - 80%
7Y3Z StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
7Y3Z StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.74
7Y3Z StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £11.55
7Y3Z StarTech.com 8 Port VGA Video Extender over Cat 5 In Stock £180.25
7Y3Z StarTech.com 4 Port VGA Over CAT5 Video Extender - 450ft (150m) In Stock £107.95
7Y3Z StarTech.com 25 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 25ft Patch Cord In Stock £4.17
Type: Extender
Price Range Ex VAT: 50 - 100
