The ST1212T 2-Port VGA over Cat 5 Extender is designed for use with the ST121 VGA over Cat 5 extension series, offering convenient video distribution at distances of up to 500 feet (150 meters) using standard Cat 5 (or better) Ethernet cabling. Comprised of the transmitter unit only, the ST1212T requires one Receiver Unit (ST121R) per display that you are connecting.
For added versatility, the VGA over Cat 5 Repeater (ST121EXT) can be used to extend the distance between the transmitter and receiver by an additional 500 feet (150 meters), for a total extension distance of 1000 feet (300 meters). Similarly, up to 3 repeater units can be used between transmitter and receiver, enabling you to connect monitors at each repeater, while still extending the total distance.
- StarTech.com 2 Port VGA over Cat5 Video Extender - Transmitter - video extender
- Video extender (transmitter)
- Form Factor
- External
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 150 m
- 6 cm x 10.2 cm x 2 cm
- 200 g
- 2-year warranty
- Designed For
- P/N: ST121EXT, ST121R, SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Max Resolution
- 1600 x 1200
- 150 m
- Status Indicators
- Power
- 1 x VGA (output) - HD-15 female , 1 x VGA (input) - HD-15 male , 2 x display / video - output - RJ-45 female
- FCC, RoHS
- Power Device
- External power adapter
- 6 cm
- 10.2 cm
- 2 cm
- 200 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
