Share a VGA monitor/projector between 2 VGA sources, with automatic/priority switching and EDID Emulation. The ST122VGA 2-Port VGA Auto Switcher lets you share a display between two computers and automatically switch to the active source device using configurable priority switching. When the port you have selected as the primary input is turned off, the device automatically switches to the secondary input.
For maximum control and versatility, the ST122VGA also offers manual switch control with an easy-to-use button that allows you to toggle between video sources.
For a convenient setup the switcher can be powered using the included power adapter or the USB power cable, and features built-in EDID emulation ensuring maximum compatibility with your display or projector and support for resolutions up to 1920x1200/1080p.
The ST122VGA includes mounting hardware for a tidy and professional installation.
- StarTech.com 2-Port VGA Auto Switch Box w/ Priority Switching and EDID Copy - monitor switch - 2 ports
- Monitor switch - 2 ports
- Subtype
- VGA
- Ports
- 2 x VGA
- KVM Users Qty
- 2 local users
- 5.9 cm x 2.1 cm x 7.4 cm
- 175 g
- Black
- 2-year warranty
- Designed For
- P/N: SVA5N3NEUA
- Enclosure Type
- Desktop
- Subtype
- VGA
- Ports
- 2 x VGA
- KVM Local Users Qty
- 2 local users
- Max Resolution
- 2048 x 1152
- Status Indicators
- Port status
- 2 x VGA input HD-15 , 1 x VGA output HD-15
- Black
- FCC, RoHS
- 5.9 cm
- 2.1 cm
- 7.4 cm
- 175 g
- Limited warranty - 2 years
- Designed For
- P/N: SVA5N3NEUA
StarTech.com 2x1 HDMI VGA to HDMI Converter | In Stock | £138.85 |
StarTech.com 4-Port 4K HDMI Video Switch | In Stock | £146.05 |
StarTech.com 2-Port 4K HDMI Video Switch | In Stock | £99.96 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.15 |
