Switch between 2 VGA signals on a single display; features automatic, prioritized switching. The ST122VGAU VGA Auto Switcher lets you share a display between two computers and prioritize your VGA signals. The VGA switch features a primary and secondary VGA input port, and automatically outputs the signal from the primary input. When the signal feed connected to the primary input port is cut, the switcher automatically defaults to the video signal on the secondary VGA input port. Designed for maximum control and versatility, the VGA Auto switcher also offers manual control of connected signals with easy-to-use front panel buttons that allow you to toggle between video sources.
StarTech.com 2 Port VGA Auto Switch - VGA auto Switcher - VGA auto Switch - 2 Port VGA Switch (ST122VGAU) - monitor switch - 2 ports
Monitor switch - 2 ports
Subtype
VGA
Ports
2 x VGA
KVM Users Qty
2 local users
13 cm x 7.6 cm x 4.2 cm
400 g
1-year warranty
P/N: SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
KVM Local Users Qty
2 local users
Max Resolution
1920 x 1440
Max Video Bandwidth
250 MHz
Status Indicators
Port status
2 x VGA input HD-15 , 1 x VGA output HD-15
External power adapter
DDC-1, DDC-2B, DDC-2B+, FCC, RoHS
13 cm
7.6 cm
4.2 cm
400 g
Limited warranty - 1 year
6PFV StarTech.com 2x1 HDMI VGA to HDMI Converter In Stock £128.61
6PFV StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
6PFV StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
