Switch between 2 VGA signals on a single display; features automatic, prioritized switching. The ST122VGAU VGA Auto Switcher lets you share a display between two computers and prioritize your VGA signals. The VGA switch features a primary and secondary VGA input port, and automatically outputs the signal from the primary input. When the signal feed connected to the primary input port is cut, the switcher automatically defaults to the video signal on the secondary VGA input port. Designed for maximum control and versatility, the VGA Auto switcher also offers manual control of connected signals with easy-to-use front panel buttons that allow you to toggle between video sources.
- StarTech.com 2 Port VGA Auto Switch - VGA auto Switcher - VGA auto Switch - 2 Port VGA Switch (ST122VGAU) - monitor switch - 2 ports
- Monitor switch - 2 ports
- Subtype
- VGA
- Ports
- 2 x VGA
- KVM Users Qty
- 2 local users
- 13 cm x 7.6 cm x 4.2 cm
- 400 g
- Black
- 1-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- VGA
- Ports
- 2 x VGA
- KVM Local Users Qty
- 2 local users
- Max Resolution
- 1920 x 1440
- Max Video Bandwidth
- 250 MHz
- Status Indicators
- Port status
- 2 x VGA input HD-15 , 1 x VGA output HD-15
- Power Device
- External power adapter
- Black
- DDC-1, DDC-2B, DDC-2B+, FCC, RoHS
- 13 cm
- 7.6 cm
- 4.2 cm
- 400 g
- Limited warranty - 1 year
- Designed For
