StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention
Quicklinx: 7B5NWS00 Mfr#: ICUSB2324852
Hurry, only 2 left in stock!
£67.61 ex VAT
£81.13 inc VAT
The ICUSB2324852 2-port, wall-mountable USB Serial Adapter lets you connect every type of serial device to your USB-enabled computer, whether it be for RS232, RS422, or RS485 communication. The adapter features a 9-pin (DB9) male and a 5-pin terminal block serial connector as well as dipswitch controls for easy port configuration with minimal software requirements. The adapter also supports using 2 ports simultaneously, including with mixed protocols; for example RS-232 on port 1, and RS-485 on port 2, or a number of other combinations.
For a convenient, and clean installation in an office or industrial setting, the RS232/RS422/RS485 USB Adapter is wall-mountable and fully powered via the host USB connection, providing power to the attached serial device without requiring an external power adapter.
StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention - serial adapter - 2 ports
Serial adapter
External
Interface (Bus) Type
USB 2.0
4.4 cm x 8.2 cm x 2.3 cm
300 g
Ports Qty
2 ports
RS-232, RS-422, RS-485
Data Transfer Rate
921.6 Kbps
Grey
Apple MacOS 6.0, Linux 2.4 or later, Microsoft Windows XP Embedded, Microsoft Windows 98SE/2000/ME/XP, Apple MacOS 9.x or later, Microsoft Windows 7, Microsoft Windows Mobile 5.0, Microsoft Pocket PC 2003, Microsoft Windows CE 4.2, Microsoft Windows Vista, Microsoft Windows Mobile 6.0, Microsoft Windows 2003, Microsoft Windows Server 2008, Microsoft Windows CE 6.0
Serial adapter - 2 ports
External
USB 2.0
Wired
Data Transfer Rate
921.6 Kbps
Status Indicators
USB powered, wall mountable
1 x RS-232/422/485 - 9 pin D-Sub (DB-9) - male , 1 x RS-422/485 - terminal block
FCC, RoHS
Grey
4.4 cm
8.2 cm
2.3 cm
300 g
55 °C
5 - 95%
7B5N StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
7B5N StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
7B5N StarTech.com DB9 to RJ45 Modular Adapter - F/F In Stock £1.23
7B5N StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F In Stock £5.93
7B5N StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £3.88
Price Range Ex VAT: 50 - 100
