StarTech.com 2 Port USB DisplayPort Cable KVM Switch w/ Audio and Remote Switch - USB Powered
Quicklinx: 93WSWS00 Mfr#: SV211DPUA
Control two DisplayPort, USB equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. The SV211DPUA 2-Port DisplayPort Cable KVM Switch with Audio and Remote Switching Control lets you control two DisplayPort, USB equipped PCs with a single monitor, keyboard, mouse and audio peripheral set.
To help organize your desk without sacrificing work space, this compact DisplayPort USB KVM features integrated cables that can be connected directly to your system, while leaving a minimal footprint. The switch features a remote push-button on a 1.5 meter (5ft) integrated cable that can be placed in an easily accessible location, as well as keyboard hot-keys, and PC or Mac compatible software for switching between systems. To eliminate the need for a bulky external power adapter and wall outlet, the DisplayPort KVM switch is USB-powered.
This KVM with DisplayPort video capability offers support for resolutions up to 2560x1600 for the ability to drive a large DisplayPort display for applications that require high graphical output.
StarTech.com 2 Port DisplayPort Cable KVM Switch with Audio & Remote Control - 2560x1600 @60Hz- USB Powered - Dual Port DP USB KVM Switch (SV211DPUA) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
USB powered, HDCP compliant, remote switch
2.5 cm x 6 cm x 8.8 cm
400 g
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600
Status Indicators
Port status
2 x DisplayPort , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 3 x headphones mini-jack , 3 x microphone mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
2 x keyboard / mouse / video / audio cable - 85 cm , 1 x remote control cable - 1.5 m
FCC, RoHS
Software Included
Drivers & Utilities
2.5 cm
6 cm
8.8 cm
400 g
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
93WS StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.91
93WS StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £4.94
93WS StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £277.08
93WS StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £192.19
93WS StarTech.com DisplayPort USB KVM Switch In Stock £288.72
93WS StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
93WS StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £5.89
93WS StarTech.com 1m Slim 3.5mm Stereo Extension Audio Cable - M/F In Stock £5.37
93WS StarTech.com 1m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £5.46
93WS StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.53
93WS StarTech.com 2 Port USB HDMI Cable KVM Switch w/ Audio and Remote Switch In Stock £78.35
93WS StarTech.com 2 Port USB VGA Cable KVM Switch - USB Powered with Remote Switch In Stock £40.74
93WS StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.70
93WS StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £395.01
93WS StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £268.79
93WS StarTech.com 4 Port DisplayPort KVM Switch 4K 60Hz In Stock £378.71
93WS StarTech.com 4PT Dual DP KVM Switch 4K60 In Stock £656.24
93WS StarTech.com 2 Pt DisplayPort KVM In Stock £331.28
93WS StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £85.19
93WS StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £102.14
93WS StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
