Add two 10Gbps USB Type-A ports to your computer, through a PCI Express slot. This USB 3.1 card lets you add two USB Type-A ports to your computer, through a PCI Express slot. It enables you to upgrade your current system by adding two USB 3.1 Gen 2 ports to your computer and giving you access to data transfer speeds up to 10Gbps.
By adding 10Gbps USB ports to your computer, you can harness the speed of USB 3.1 Gen 2 and rest assured you're ready for both current and future high-bandwidth USB-A devices.
With higher data throughput support, this PCI Express USB 3.1 card is a necessity for external drives, drive enclosures, and many other USB 3.1 peripherals. Plus, the USB card includes an optional SATA power connector to connect to your system power supply and deliver up to 900mA of power per port to USB 3.1 bus-powered devices (500mA for USB 2.0). The card is ideal for use with large external storage solutions.
Connecting older peripherals isn't a problem. This versatile dual-port USB 3.1 card is backward compatible with legacy USB 3.0/2.0 devices that use the common USB Type-A port, so you can eliminate the added expense and aggravation of purchasing new devices.
The USB 3.1 PCIe card is compatible with a broad range of Windows and Linux operating systems. Plus, the high-quality card includes both standard-profile and low-profile brackets, making it easy to install in full or small form-factor PCs and servers.
- StarTech.com 2-Port USB PCIe Card - 10Gbps USB 3.1 Gen 2 Type-A PCI Express Host Controller Expansion Card (PEXUSB312A2) - USB adapter - PCIe 3.0 x4 - USB 3.1 Gen 2 x 2
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 3.0 x4
- Ports
- USB 3.1 Gen 2 x 2
- 1.08 cm x 12.2 cm x 2.1 cm
- 50 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0, USB 3.1
- Data Transfer Rate
- 10 Gbps
- Processor
- ASMedia ASM2142
- xHCI
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.4.x LTS versions
- Limited lifetime warranty
- Designed For
- P/N: SDOCK4U313
- USB adapter
- Form Factor
- Ports
- USB 3.1 Gen 2 x 2
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
- 10 Gbps
- xHCI
Processor / Memory
- Processor
- ASMedia ASM2142
- 2 x USB 3.1 - 9 pin USB Type A , 1 x SATA power - 15 pin Serial ATA power (internal)
- Included Accessories
- Low-profile bracket
- FCC, RoHS, UASP (USB Attached SCSI Protocol)
- OS Required
- 1.08 cm
- 12.2 cm
- 2.1 cm
- 50 g
- Limited warranty - lifetime
- 5 °C
- 50 °C
- 20 - 80%
- Designed For
- P/N: SDOCK4U313
