StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter
Quicklinx: 7TH1WS00 Mfr#: USB3SPLATE
18 in stock
£14.46 ex VAT
£17.35 inc VAT
The USB3SPLATE 2-port USB 3.0 A slot plate converts the USB pins on the USB 3.0 motherboard header to 2 standard USB 3.0 A-type ports. The plate can be mounted on the rear panel of a computer case, adding two USB 3.0 A female ports for simple connection to USB peripheral devices.
The USB 3.0 standard supports transfer rates of up to 5Gbps, and provides connectivity and support for older USB 2.0 (480Mbps) and 1.1 (12Mbps) devices.
StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter - USB 3.0 motherboard Adapter - USB 3 plate - USB 3.0 header Adapter (USB3SPLATE) - USB panel - USB Type A to 20 pin IDC - 50 cm
USB panel
Double shielded
Length
50 cm
Connector
2 x 9 pin USB Type A - female
Connector (Second End)
20 pin IDC - female
USB / USB 2.0 / USB 3.0
Blue
P/N: PEXUSB312EIC
USB panel
Double shielded
American Wire Gauge (AWG)
28
Length
50 cm
Blue
Connector
20 pin IDC - female
USB / USB 2.0 / USB 3.0, RoHS
P/N: PEXUSB312EIC
Stock Status: In stock
