Product
StarTech.com 2 Port USB 3.0 A Female Low Profile Slot Plate Adapter
Quicklinx: 80HTWS00 Mfr#: USB3SPLATELP
£14.58 ex VAT
£17.49 inc VAT
The USB3SPLATELP 2-Port USB 3.0 A Female Low Profile Slot Plate converts the USB pins on a USB 3.0 motherboard header to 2 standard USB 3.0 A-style ports. An ideal solution for small form factor computer cases, the plate can be mounted on the rear panel of a low profile or thin client computer case, adding two USB 3.0 A female ports for simple connection to USB peripheral devices.
The USB3SPLATELP is ideal for small form factor computer cases. The USB 3.0 standard supports transfer rates of up to 5 Gbps, and provides connectivity and support for older USB 2.0 and 1.1 devices.
StarTech.com 2 Port USB 3.0 A Female Low Profile Slot Plate Adapter - USB panel - 50 cm
USB panel
Shielded
Low profile
Length
50 cm
Connector
2 x 9 pin USB Type A - female
Connector (Second End)
20 pin IDC - female
USB 3.0
Blue
USB panel
Shielded
American Wire Gauge (AWG)
28
Low profile
Length
50 cm
Blue
Connector
20 pin IDC - female
USB 3.0, RoHS
Price Range Ex VAT: 0 - 50
