The USB3SPLATELP 2-Port USB 3.0 A Female Low Profile Slot Plate converts the USB pins on a USB 3.0 motherboard header to 2 standard USB 3.0 A-style ports. An ideal solution for small form factor computer cases, the plate can be mounted on the rear panel of a low profile or thin client computer case, adding two USB 3.0 A female ports for simple connection to USB peripheral devices.
The USB3SPLATELP is ideal for small form factor computer cases. The USB 3.0 standard supports transfer rates of up to 5 Gbps, and provides connectivity and support for older USB 2.0 and 1.1 devices.
- StarTech.com 2 Port USB 3.0 A Female Low Profile Slot Plate Adapter - USB panel - USB Type A to 20 pin IDC - 50 cm
- USB panel
- Technology
- Shielded
- Low profile
- Length
- 50 cm
- Connector
- 2 x 9 pin USB Type A - female
- Connector (Second End)
- 20 pin IDC - female
- USB 3.0
- Blue
- Limited lifetime warranty
- USB panel
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Low profile
- Length
- 50 cm
- Blue
- Connector
- USB 3.0, RoHS
