StarTech.com 2 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m)
Quicklinx: 7P3PWS00 Mfr#: USB2002EXT2
Type: USB Extender
Interface: USB, USB 2.0
Speed: 480Mbps
Ports: 2
Form Factor: External
£328.95 ex VAT
£394.74 inc VAT
Extend two USB 2.0 connections with power, by up to 330ft over Cat5 or Cat6 cable. The USB2002EXT2 2-Port USB Extender lets you extend USB 2.0 devices over Cat 5 or better Ethernet cable at distances of up to 330ft (100m). A local transmitter power adapter provides up to 500 mA of power per port with no power adapter required at the remote end, letting you access and power almost any USB 2.0 device in locations where a power outlet may be unavailable.
This USB extender provides support for data transfer rates of up to 480 Mbps, is Plug-and-Play and hot-swap compatible, and is also backwards compatible with USB 1.x devices.
This versatile USB extender offers a fast, easy, and flexible solution for business or industrial applications with durable metal housing, and an included surface-mounting bracket kit.
StarTech.com 2 Port USB 2.0 over Cat5 or Cat6 Extender Local / Remote Power - USB extender - USB, USB 2.0
USB extender
Ports Qty
2
External
Data Transfer Rate
480 Mbps
USB, USB 2.0
Max Transfer Distance
100 m
AC 120/230 V
Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0
7.6 cm x 10 cm x 2.6 cm
0.6 kg
USB extender
External
Ports Qty
2
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
100 m
Status Indicators
Power, link OK, link/activity
1 x USB 2.0 - Type A male , 2 x USB 2.0 - Type A female
FCC, RoHS
External power adapter
AC 120/230 V
7.6 cm
10 cm
2.6 cm
0.6 kg
50 °C
10 - 90%
7P3P StarTech.com 3 ft Mini USB 2.0 Cable - A to Mini B In Stock £3.18
7P3P StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B In Stock £3.31
7P3P StarTech.com 15 ft Transparent USB 2.0 Cable - A to B In Stock £4.72
7P3P StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
7P3P StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.81
7P3P StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
7P3P StarTech.com 6 ft Transparent USB 2.0 Cable - A to B In Stock £3.70
7P3P StarTech.com 6in Mini USB 2.0 Cable - A to Mini B In Stock £3.07
7P3P StarTech.com 3 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.87
7P3P StarTech.com 2 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m) In Stock £328.95
7P3P StarTech.com 4 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m) In Stock £316.75
7P3P StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) In Stock £70.01
7P3P StarTech.com 1 Port USB 2.0 over Cat5 / Cat6 Ethernet Extender - up to 330ft (100m) In Stock £264.25
7P3P StarTech.com 4 Port USB 2.0 over Gigabit LAN or Direct Cat5e / Cat6 Ethernet Extender - up to 330 ft In Stock £414.71
Type: USB Extender
Interface: USB
Interface: USB 2.0
Speed: 480Mbps
Ports: 2
Price Range Ex VAT: 300 - 500
