Your basket is empty
StarTech.com 2 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub
Quicklinx: 8G5SWS00 Mfr#: SV231TDVIUA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
Hurry, only 2 left in stock!
£278.42 ex VAT
£334.10 inc VAT
Switch between two triple head computers, while sharing three DVI displays, speakers & mic, USB Keyboard/Mouse, and USB 2.0 peripherals. The SV231TDVIUA 2-Port Triple Monitor DVI USB KVM Switch allows 2 PCs (each with 3 DVI video outputs) to share monitors, 1 microphone and set of speakers, 1 keyboard and 1 mouse, as well as an additional USB 2.0 peripheral such as an external hard drive, thumb drive, printer, or webcam.
The Triple DVI KVM switch enables you to switch back and forth between 2 multi DVI PCs at the touch of a button, while maintaining professional-level video quality on all monitors at resolutions up to 1920x1200. The triple monitor DVI switch also features an integrated USB hub port which allows USB 2.0 peripherals to be shared between attached systems, eliminating duplicate peripheral costs and offering the convenience of sharing stored data between PCs.
While both DVI-I (analog mode) and DVI-D (digital only) are supported by the KVM, both source PCs must output the same signal type for proper switching. It is recommended, wherever possible, to use DVI-D cables across all PC to KVM and KVM to Console connections.
StarTech.com 2 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub - KVM / audio / USB switch - 2 ports
KVM / audio / USB switch - 2 ports - USB
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2 port USB 2.0 hub, HDCP compliant
AC 120/230 V
15.9 cm x 7.4 cm x 10 cm
0.9 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200
Status Indicators
Port status
2 x USB 2.0 - Type B , 3 x DVI-I , 2 x audio / headphones - mini-jack , 2 x microphone input - mini-jack , 6 x DVI-I , 4 x USB 2.0 - Type A , 1 x audio / headphones - mini-jack , 1 x microphone input - mini-jack
External power adapter
AC 120/230 V
FCC, RoHS
15.9 cm
7.4 cm
10 cm
0.9 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
8G5S StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £3.45
8G5S StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £11.53
8G5S StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £8.93
8G5S StarTech.com 3 ft DVI-D Dual Link Cable - M/M In Stock £6.05
8G5S StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £16.36
8G5S StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £20.60
8G5S StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £29.33
8G5S StarTech.com 3.5 mm to 3.5 mm Audio Coupler - Female to Female In Stock £4.86
8G5S StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.26
Connectivity: KVM
Ports: 2
Price Range Ex VAT: 150 - 300
