Control 2 VGA, USB 3.0 equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. The SV231U3A 2 Port SuperSpeed USB 3.0 VGA KVM Switch with Audio and Cables lets you control 2 VGA, USB 3.0 equipped PCs with a single monitor, keyboard, mouse and audio peripheral set.
This USB 3.0 KVM Switch offers an integrated 2 port hub that supports USB 3.0 data rates of up to 5 Gbps, and is backward compatible with USB 2.0 and 1.1/1.0 devices, ensuring flawless performance for your USB peripherals.
Offering support for high resolutions (up to 2048x1536), this 2 port VGA KVM switch has the ability to drive large VGA displays with ease, ideal for graphical applications that require high-res video output.
- StarTech.com 2 Port SuperSpeed USB 3.0 VGA KVM Switch with Audio and Cables - KVM switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Power
- AC 120/230 V
- 16.5 cm x 8.9 cm x 4.6 cm
- 0.94 kg
- Black
- Localisation
- North America, United Kingdom, Europe
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536
- Built-in Devices
- USB 3.0 hub
- Status Indicators
- Port status
- 2 x USB 3.0 Type B , 2 x VGA HD-15 , 2 x audio / headphones mini-jack , 2 x microphone input mini-jack , 2 x USB 3.0 Type A , 1 x VGA HD-15 , 1 x audio / headphones mini-jack , 1 x microphone input mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Cables Included
- 2 x VGA cable , 2 x USB cable , 2 x audio cable
- FCC, RoHS
- Localisation
- 16.5 cm
- 8.9 cm
- 4.6 cm
- 0.94 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 40 °C
