StarTech.com 2 Port SFP+ 10G Fiber w/ Chassis
Quicklinx: DXG5WS00 Mfr#: BNDTB210GSFP
This Thunderbolt 3 network adapter connects your Thunderbolt 3 enabled device to a 10GbE fiber network via a PCIe expansion chassis. This Thunderbolt 3 to fiber network adapter connects your Thunderbolt 3 enabled device to a 10GbE network. The adapter combines the Thunderbolt 3 technology of TB31PCIEX16 with the 10GbE dual-fiber connection of PEX20000SFPI (Intel 82599 chipset). The assembled adapter features one DisplayPort output, one additional Thunderbolt 3 port, and two open 10GbE SFP+ slots.
This Thunderbolt 3 to fiber network adapter is the perfect solution for your mission-critical operations. The network adapter supports 802.1Q VLAN tagging for better bandwidth, 802.3ad link aggregation for greater network speeds, network redundancy support for reliability, and two 10G fiber connections through open SFP+ fiber slots for building a custom setup.
Requiring only a Phillips type screwdriver and your choice of SFPs, this Thunderbolt 3 to 10G fiber network adapter can be assembled and connected in minutes.
The Thunderbolt 3 chassis not only pairs well with the 10G fiber network card - you can swap in other PCIe cards to help support other functionality and performance. With the extra TB3 port and DP output built into the chassis, you will always have the ability to hook up extended displays to multitask effortlessly.
StarTech.com Thunderbolt 3 to 10GbE Fiber Network Chassis - External PCIe enclosure - 2 Open SFP+ Ports - network adapter - PCIe 3.0 x8 - 10 Gigabit SFP+ x 2
Network adapter
Plug-in card - low profile
Bundled with
Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
Interface (Bus) Type
PCI Express 3.0 x8
Ports
10 Gigabit SFP+ x 2
10GbE
Data Transfer Rate
10 Gbps
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016
Network adapter
Bundled with
PCI Express 3.0 x8
Ports
10 Gigabit SFP+ x 2
Wired
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
2 x 10GBase-X - SFP+
Low-profile bracket
1 x Thunderbolt cable (external)
5 °C
50 °C
20 - 80%
DXG5 StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length In Stock £320.28
DXG5 StarTech.com PCI Express to 4 Slot PCI Expansion System In Stock £361.27
