The PEXSAT32 2-Port PCI Express SATA 6 Gbps (SATA 3.0) Controller Card offers simple connectivity between a host computer and SATA 3.0 devices - a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives and Solid State Drives (SSD), which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The controller card is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a host PC through a single external SATA connection.
A dual profile solution, the SATA 3.0 controller card includes a low profile bracket for installation in slimline or small form factor computer cases.
- StarTech.com 2 Port SATA 6 Gbps PCI Express SATA Controller Card - Dual Port PCIe SATA III Card Adapter (PEXSAT32) - storage controller - SATA 6Gb/s - PCIe
- Storage controller - plug-in card
- Bus Type
- PCIe
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive
- Channel Qty
- 2
- Max Storage Devices Qty
- 2
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Linux 3.5.x - 4.11.x LTS versions only
- 64.5 cm x 67.7 cm x 21.3 cm
- 67.9 g
- Limited lifetime warranty
- Designed For
- P/N: ST521PMINT
- Host Bus
- PCIe
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Hard drive
- Channel Qty
- 2
- 2
- Processor
- Marvell 88SE9128
- 2 x SATA 6Gb/s - SATA
- Compatible Slots
- 1 x PCI Express
- WHQL, FCC, RoHS
- OS Required
- Limited warranty - lifetime
- 64.5 cm
- 67.7 cm
- 21.3 cm
- 67.9 g
- Designed For
- P/N: ST521PMINT
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.34 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.58 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.40 |
StarTech.com 18in Latching SATA Cable | In Stock | £4.48 |
StarTech.com 24in Latching SATA Cable | In Stock | £5.98 |
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable | In Stock | £4.86 |
StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext | In Stock | £30.82 |
StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering | In Stock | £67.82 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.24 |
