Your basket is empty
StarTech.com 2 Port RS232 Serial over IP Ethernet Device Server
Quicklinx: 5CC1WS00 Mfr#: NETRS232_2GB
This two port Ethernet-to-Remote Serial interface converter lets you install RS 232 serial devices anywhere on your TCP/IP Ethernet WAN/LAN, and your serial devices will perform as if they were right beside you - even over the Internet!
Even at the longest distances, control of your serial devices will be right at your fingertips: the remote serial ports appear alongside your local serial ports in your Windows device manager.
The Serial Ethernet IP Adapter (Device Server, Console Server) is designed to function seamlessly with your other serial ports for totally transparent operation. Your serial equipment - card scanners, access keypads, bar code scanners, and more - will operate as smoothly as if the serial ports were right inside your computer.
For industrial automation, security, Point of Sale, or any time you need reliable, long-range serial communications, this converter will deliver superior performance in any environment.
StarTech.com 2 Port RS232 Serial over IP Ethernet Device Server - device server
Device server
External
United Kingdom
Ports Qty
2
Ethernet, RS-232
Linux, Microsoft Windows 2000 / XP
Device server
Enclosure Colour
Beige
United Kingdom
External
Ports Qty
2
Wired
Data Transfer Rate
115.2 Kbps
Ethernet, RS-232
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP
Remote Management Protocol
Telnet, HTTP
Status Indicators
Transmit, receive
Firmware upgradable
2 x RS-232 - DB-9 , 1 x 10Base-T
UL, FCC
External power adapter
Software Included
Drivers & Utilities, Ether Link Manager
Limited warranty - lifetime
