Add 2 RS-232 serial ports to your standard or small form factor computer through a PCI Express expansion slot. The PEX2S553B 2-Port PCI Express Serial Card w/ Breakout Cable lets you add two RS232 serial ports using a single PCIe expansion slot. With the included break-out cable, you can easily add two ports to a single low profile slot.
The PCIe serial card features a native single-chip design that provides optimum reliability and speed, reducing the CPU load by up to 48% over conventional bridge-chip serial cards - a cost-effective solution for connecting legacy serial devices to PCIe enabled computers.
The multiport PCIe Serial Adapter includes both full and low-profile/half-height brackets for compatibility with standard and small form factor computers, and is compatible with a broad range of operating systems, including Windows 7/Server 2008 R2, 2003/Vista/XP (32 and 64 bit), Linux Kernel 2.6.11 and up, as well as MAC OS 10.5 and above.
This product is a replacement for the PEX2S552B card.
- StarTech.com 2 Port RS232 PCI Express Serial Card w/ Breakout Cable - serial adapter - PCIe - RS-232 x 2
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express
- Ports
- RS-232 x 2
- 8 cm x 8 cm x 2.3 cm
- Cabling Type
- Serial RS-232
- Data Transfer Rate
- 250 Kbps
- Processor
- MosChip Semiconductor
- System Requirements
- Linux, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Apple MacOS X 10.4 or later, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows CE 6.0, Microsoft Windows Server 2003 (32/64-bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI Express
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- Cabling Type
- Serial RS-232
- 250 Kbps
- Flow control
Processor / Memory
- Processor
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express
- WHQL, RoHS
- OS Required
- 8 cm
- 8 cm
- 2.3 cm
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 5 - 85%
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
