Product
StarTech.com 2 Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub
Quicklinx: 7B7RWS00 Mfr#: SV231QDVIUA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
£373.54 ex VAT
£448.24 inc VAT
Switch between two Computers sharing four DVI displays, speakers & mic, USB Keyboard & Mouse, and USB 2.0 peripheral. The SV231QDVIUA 2-Port Quad Monitor Dual-Link DVI USB KVM Switch allows 2 PCs, each with 4 DVI video outputs, to share monitors, 1 microphone and set of speakers, 1 keyboard and 1 mouse as well as an additional USB 2.0 peripheral such as an external hard drive, thumb drive, printer, or webcam.
The Quad DVI KVM switch allows you to switch back and forth between 2 multi DVI PCs at the touch of a button, while maintaining professional-level video quality on all monitors at resolutions up to 2560x1600. The quad DVI switch also features an integrated USB hub port that allows USB 2.0 peripherals to be shared between attached systems - eliminating duplicate peripheral costs, and offering the convenience of sharing stored data between PCs.
While both DVI-I (analog mode) and DVI-D (digital only) are supported by the KVM, both source PCs must output the same signal type for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
StarTech.com 2 Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub - KVM / audio / USB switch - 2 ports
Enclosure Type
1U
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
AC 120/230 V
43.8 cm x 17.8 cm x 4.3 cm
3 kg
3-year warranty
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600
Status Indicators
Port status, power
8 x DVI-D (dual link) , 4 x keyboard (USB) / mouse (USB) Type B , 2 x microphone input mini-jack , 2 x speakers mini-jack , 4 x DVI-D (dual link) , 1 x microphone input mini-jack , 1 x speakers mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 1 x USB 2.0 Type A
External power adapter
AC 120/230 V
Rack Mounting Kit
Included
DDC-2B, FCC, RoHS
43.8 cm
17.8 cm
4.3 cm
3 kg
Limited warranty - 3 years
0 - 80%
7B7R StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £3.46
7B7R StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
7B7R StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £12.91
7B7R StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
7B7R StarTech.com 3 ft DVI-D Dual Link Cable - M/M In Stock £4.15
7B7R StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £16.27
7B7R StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £19.64
7B7R StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £27.96
7B7R StarTech.com 3.5 mm to 3.5 mm Audio Coupler - Female to Female In Stock £4.85
7B7R StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £1.36
7B7R StarTech.com 2 Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub In Stock £373.54
Connectivity: KVM
Ports: 2
Price Range Ex VAT: 300 - 500
