Switch between two Computers sharing four DVI displays, speakers & mic, USB Keyboard & Mouse, and USB 2.0 peripheral. The SV231QDVIUA 2-Port Quad Monitor Dual-Link DVI USB KVM Switch allows 2 PCs, each with 4 DVI video outputs, to share monitors, 1 microphone and set of speakers, 1 keyboard and 1 mouse as well as an additional USB 2.0 peripheral such as an external hard drive, thumb drive, printer, or webcam.
The Quad DVI KVM switch allows you to switch back and forth between 2 multi DVI PCs at the touch of a button, while maintaining professional-level video quality on all monitors at resolutions up to 2560x1600. The quad DVI switch also features an integrated USB hub port that allows USB 2.0 peripherals to be shared between attached systems - eliminating duplicate peripheral costs, and offering the convenience of sharing stored data between PCs.
While both DVI-I (analog mode) and DVI-D (digital only) are supported by the KVM, both source PCs must output the same signal type for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
- StarTech.com 2-Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub (SV231QDVIUA) - KVM / audio / USB switch - 2 ports
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Power
- AC 120/230 V
- 43.8 cm x 17.8 cm x 4.3 cm
- 3 kg
- Black
- 3-year warranty
- Designed For
- P/N: DVID4N1USB10, DVID4N1USB15, DVID4N1USB6, IM12D1500P, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2560 x 1600
- Status Indicators
- Port status, power
- 8 x DVI-D (dual link) , 4 x keyboard (USB) / mouse (USB) Type B , 2 x microphone input mini-jack , 2 x speakers mini-jack , 4 x DVI-D (dual link) , 1 x microphone input mini-jack , 1 x speakers mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 1 x USB 2.0 Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Rack Mounting Kit
- Included
- DDC-2B, FCC, RoHS
- 43.8 cm
- 17.8 cm
- 4.3 cm
- 3 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M | In Stock | £4.57 |
StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F | In Stock | £4.91 |
StarTech.com 12 ft PC Speaker Extension Audio Cable | In Stock | £4.94 |
StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £10.71 |
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £269.04 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £277.79 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £197.20 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £166.96 |
StarTech.com 3.5 mm to 3.5 mm Audio Coupler - Female to Female | In Stock | £5.41 |
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.00 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £288.93 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £318.91 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £657.51 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
