StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power
Quicklinx: 8GTNWS00 Mfr#: PCIUSB3S22
Type: USB adapter
Compatibility: PC
Interface: PCI-X
  • Windows 8 (32/64 bits)
20 in stock
£41.62 ex VAT
£49.94 inc VAT
Add 2 SuperSpeed USB 3.0 ports to a computer through a PCI slot. The PCIUSB3S22 2-Port PCI to USB 3.0 Card enables you to connect USB 3.0 peripherals to a PC through a legacy PCI host bus, which doubles the data transfer speeds when used with USB 3.0 peripherals than would be possible with a USB 2.0 host connection - up to 1.3 Gbps (PCI bus limit).
The card features an optional SATA power connection, which enables each port to supply up to 900mA of power to USB 3.0 bus-powered devices.
By supporting a legacy (PCI) host connection, the card adds updated peripheral connectivity, without having to upgrade to a PCIe-equipped motherboard or rely on the backward compatibility of USB 3.0 peripherals.
StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power - Dual Port PCI USB 3 Controller Card (PCIUSB3S22) - USB adapter
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI-X
Bus Voltage
Universal (3.3 V & 5.0 V)
Ports
USB 3.0 x 2
1 cm x 12.3 cm x 5.6 cm
60 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
NEC uPD720202
USB 1.1, USB 2.0, USB 3.0
Red
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
P/N: S3510BMU33, S3510SMU33, ST7300USB3B, UNI251BMU33
USB adapter
PCI-X
Bus Voltage
Ports
USB 3.0 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Processor / Memory
NEC uPD720202
2 x USB 3.0 - 9 pin USB Type A
Compatible Slots
1 x PCI-X
Low-profile bracket
FCC, RoHS
Red
Software Included
Drivers & Utilities
1 cm
12.3 cm
5.6 cm
60 g
Limited warranty - lifetime
5 °C
50 °C
15 - 90%
8GTN StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £7.61
8GTN StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £2.92
8GTN StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.88
8GTN StarTech.com 7 Port PCI USB Card Adapter In Stock £14.67
8GTN StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.21
8GTN StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £6.34
8GTN StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £5.96
8GTN StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power In Stock £41.62
8GTN StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power In Stock £49.19
Type: USB adapter
Compatibility: PC
Interface: PCI-X
Price Range Ex VAT: 0 - 50
