StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART
Quicklinx: 3ZRWWS00 Mfr#: PCI2S550
Type: Serial adapter
Compatibility: PC
Interface: PCI
  • Windows 8 (32/64 bits)
£19.47 ex VAT
£23.36 inc VAT
Add 2 high-speed RS-232 serial ports to your PC through a PCI expansion slot. The PCI2S550 2 Port 16550 Serial Card can be installed in an available PCI slot to add two RS232 serial ports to your system. A cost-effective solution for connecting any new or legacy serial device, with data transfer rates of up to 115.2 Kbps.
Perfect for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more to your system, the adapter card supports IRQ sharing and operates flawlessly with Windows 7, Server 2008 R2, XP, Server 2003, 2000, ME, 98, 95, NT4, 3.1, DOS and Linux.
The card can be connected in minutes through simple plug and play installation.
StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART - Serial adapter - PCI - RS-232 x 2 - PCI2S550 - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI
Ports
RS-232 x 2
Serial
Data Transfer Rate
115.2 Kbps
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Serial adapter
Plug-in card
PCI
Ports
RS-232 x 2
Wired
Serial
Data Transfer Rate
115.2 Kbps
2 x RS-232 - 9 pin D-Sub (DB-9) - male - 2
Compatible Slots
1 x PCI
Software Included
Drivers & Utilities
Limited warranty - parts and labour - lifetime - carry-in
3ZRW StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.84
3ZRW StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.33
3ZRW StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.90
3ZRW StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.53
3ZRW StarTech.com 2 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART In Stock £24.01
3ZRW StarTech.com 1 Port PCI RS232 Serial Adapter Card with 16550 UART In Stock £18.11
3ZRW StarTech.com 4 Port PCI RS232 Serial Adapter Card with 16550 UART In Stock £34.56
3ZRW StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.19
Resources
The following resources are available for the StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART
Compatibility: PC
Interface: PCI
Price Range Ex VAT: 0 - 50
