StarTech.com 2 Port PCI Express SATA III 6Gbps RAID Card w/ 2 mSATA Slots - storage controller (RAID)
Quicklinx: 9ZR7WS00 Mfr#: PEXMSATA3422
Compatibility: Mac, PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Hurry, only 3 left in stock!
£64.35 ex VAT
£77.22 inc VAT
Combine SSD performance with HDD capacity to create a HyperDuo RAID array with 2 x mSATA and 2 x SATA drives through a single PCI Express slot. The PEXMSATA3422 PCI Express SATA Card helps you improve the overall speed and storage capacity of your computer by giving you multiple 6 Gbps SATA connections for connecting high-performance SSDs (Solid State Drives) and hard drives in a HyperDuo RAID array. Now, you can easily add two mSATA slots and two SATA III ports to your computer through a single PCIe x4 slot.
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance! (Note: The HyperDuo automatic storage tiering feature is compatible with computers that use a BIOS.)
This versatile RAID controller card helps to relieve the internal space constraints often associated with multi-drive configurations by letting you install two mSATA SSDs directly to the card via convenient, latching slots. With dual mSATA slots, as well as two internal SATA ports, the card offers an effective hardware RAID solution, with native RAID (0, 1) support.
The PCIe SATA controller also offers Port Multiplier (PM) support, so you can connect multiple SATA drives to just one port, for a total of 7 drives (up to 4 drives through PM on one port, plus a single drive to the other SATA port and two mSATA slots).
For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
StarTech.com 2 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card w/ 2 mSATA Slots & HyperDuo SSD Tiering - PCIe SATA 3 Controller (PEXMSATA3422) - storage controller (RAID) - SATA 6Gb/s / mSATA - PCIe 2.0 x4
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe 2.0 x4
SATA 6Gb/s / mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10, JBOD
Linux, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
2 cm x 12.5 cm x 12 cm
60 g
P/N: ST521PMINT
Host Bus
PCIe 2.0 x4
Storage Controller
SATA 6Gb/s / mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
Marvell 88SE9230
2 x SATA 6Gb/s - SATA (internal) , 2 x SATA 6Gb/s - mSATA (internal)
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
2 cm
12.5 cm
12 cm
60 g
5 °C
50 °C
20 - 80%
P/N: ST521PMINT
9ZR7 StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
9ZR7 StarTech.com 12in Latching SATA Cable In Stock £3.34
9ZR7 StarTech.com 18in Latching SATA Cable In Stock £3.74
9ZR7 StarTech.com 2 Port SATA 6 Gbps PCI Express SATA Controller Card In Stock £27.79
9ZR7 StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext In Stock £27.46
9ZR7 StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering In Stock £57.58
9ZR7 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £73.56
9ZR7 StarTech.com 2 Port PCI Express SATA III 6Gbps RAID Card w/ 2 mSATA Slots - storage controller (RAID) In Stock £64.35
Compatibility: Mac
Compatibility: PC
Stock Status: In stock
