StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
Quicklinx: 5D3ZWS00 Mfr#: PEX2S952
Type: Serial adapter
Compatibility: PC, Unix
Interface: PCI Express x1
  • Windows 8 (32/64 bits)
More than 50 in stock
£26.58 ex VAT
£31.89 inc VAT
Add 2 RS-232 serial ports to your full height or low profile computer through a PCI Express slot. The PEX2S952 PCI Express based serial card turns a PCI Express slot into 2 RS-232 (DB9) serial connections.
The adapter card is based on a native single chip design, that allows you to harness the full capability of PCI Express (PCIe) - providing optimum reliability and speed while reducing the load applied to the CPU by as much as 48% over conventional (bridge chip) serial cards.
The RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows and Linux (Kernel 2.6.11 and up).
Plus, the adapter card includes an optional half-height/low profile bracket that allows the card to be installed in virtually any computer case - making it that much easier to add serial ports to a PCI Express enabled computer, regardless of the size of the computer case.
StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Bus Voltage
3.3 V
Ports
RS-232 x 2
6.5 cm x 9 cm x 2 cm
58 g
RS-232
Data Transfer Rate
460 Kbps
Green
Linux, Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Serial adapter
Plug-in card
PCI Express x1
PCIe 1.0a
Bus Voltage
3.3 V
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
460 Kbps
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Green
Software Included
Drivers & Utilities
6.5 cm
9 cm
2 cm
58 g
Limited warranty - lifetime
-10 °C
80 °C
5 - 85%
5D3Z StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
5D3Z StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
5D3Z StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
5D3Z StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
5D3Z StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
5D3Z StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
Resources
The following resources are available for the StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 0 - 50
