StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
Quicklinx: 5D3ZWS00 Mfr#: PEX2S952
Type: Serial adapter
Compatibility: PC, Unix
Interface: PCI Express x1
£26.58 ex VAT
£31.89 inc VAT
Add 2 RS-232 serial ports to your full height or low profile computer through a PCI Express slot. The PEX2S952 PCI Express based serial card turns a PCI Express slot into 2 RS-232 (DB9) serial connections.
The adapter card is based on a native single chip design, that allows you to harness the full capability of PCI Express (PCIe) - providing optimum reliability and speed while reducing the load applied to the CPU by as much as 48% over conventional (bridge chip) serial cards.
The RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows and Linux (Kernel 2.6.11 and up).
Plus, the adapter card includes an optional half-height/low profile bracket that allows the card to be installed in virtually any computer case - making it that much easier to add serial ports to a PCI Express enabled computer, regardless of the size of the computer case.
StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Bus Voltage
3.3 V
Ports
RS-232 x 2
6.5 cm x 9 cm x 2 cm
58 g
RS-232
Data Transfer Rate
460 Kbps
Green
Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Serial adapter
Plug-in card
PCI Express x1
PCIe 1.0a
Bus Voltage
3.3 V
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
460 Kbps
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Green
Software Included
Drivers & Utilities
6.5 cm
9 cm
2 cm
58 g
Limited warranty - lifetime
-10 °C
80 °C
5 - 85%
5D3Z StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
5D3Z StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
5D3Z StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
5D3Z StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
5D3Z StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.25
5D3Z StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.14
Resources
The following resources are available for the StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 0 - 50
