Add 2 RS-232 serial ports to your full height or low profile computer through a PCI Express slot. The PEX2S952 PCI Express based serial card turns a PCI Express slot into 2 RS-232 (DB9) serial connections.
The adapter card is based on a native single chip design, that allows you to harness the full capability of PCI Express (PCIe) - providing optimum reliability and speed while reducing the load applied to the CPU by as much as 48% over conventional (bridge chip) serial cards.
The RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows and Linux (Kernel 2.6.11 and up).
Plus, the adapter card includes an optional half-height/low profile bracket that allows the card to be installed in virtually any computer case - making it that much easier to add serial ports to a PCI Express enabled computer, regardless of the size of the computer case.
- StarTech.com Replaced by PEX2S953 - 2 Port PCI Express Serial Adapter Card with 16950 UART (PEX2S952) - serial adapter - PCIe - RS-232 x 2
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.0a
- Bus Voltage
- 3.3 V
- Ports
- RS-232 x 2
- 6.5 cm x 9 cm x 2 cm
- 58 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460 Kbps
- Green
- System Requirements
- Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- Limited lifetime warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
- Serial adapter
- Form Factor
- Plug-in card
- PCI Express x1
- PCIe 1.0a
- Bus Voltage
- 3.3 V
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 460 Kbps
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Green
- Software Included
- Drivers & Utilities
- OS Required
- 6.5 cm
- 9 cm
- 2 cm
- 58 g
- Limited warranty - lifetime
- -10 °C
- 80 °C
- 5 - 85%
- Designed For
