StarTech.com 2-Port mDP KVM Switch - 4K
Quicklinx: BGC0WS00 Mfr#: SV231MDPU2
Control 2 Mini DisplayPort computers with a single monitor, keyboard and mouse, using this DP 1.2 KVM switch. This versatile USB KVM switch lets you share a Mini DisplayPort (mDP) workstation with two computer systems, providing control of an mDP monitor, keyboard and mouse, plus an additional USB peripheral device. Support for mDP makes this KVM the perfect accessory for your Mac workstation.
To ensure compatibility with your setup, this KVM switch was rigorously tested with the most popular platforms including Windows, Linux and Mac computers, and is powered through your USB peripherals, meaning you won't require an external power source.
With support for resolutions up to 4K at 60hz, you'll be amazed at how this Mini DisplayPort KVM flawlessly manages your graphics-intensive content. At four times the resolution of high-definition 1080p, its lossless performance makes the switch the ideal solution for graphics-intensive applications such as CAD/ CAM design, graphic design, or health care imaging (MRI, radiology diagnostics, etc.).
Plus, the KVM switch supports 1080p displays, which makes it a great accessory for home, office or other workspace applications.
Featuring Mini DisplayPort 1.2 with 7.1 digital audio, plus a 3-port USB hub for your keyboard, mouse and an additional USB peripheral device, this KVM switch is perfect for accessing two separate systems using the same workstation - ideal for server control, simplifying access to multiple computer systems.
This 2-port KVM delivers effortless operation with hardware and software switching, providing a simple yet comprehensive solution for switching between each connected computer. The switching software that's included gives you on-demand switching using an intuitive video interface. Hotkey control is also available when working with Windows computers, plus the switch features an easy-to-access toggle switch located on the front.
To achieve the maximum resolution of 4K at 60Hz, a video source and display that support that resolution are required. Hotkey switch commands are only supported when using Windows computers.
  • Astonishing 4K picture quality
    With support for resolutions up to 4K at 60hz, you'll be amazed at how this Mini DisplayPort KVM flawlessly manages your graphics-intensive content. At four times the resolution of high-definition 1080p, its lossless performance makes the switch the ideal solution for graphics-intensive applications such as CAD/ CAM design, graphic design, or health care imaging.
  • Multi-system access
    Featuring Mini DisplayPort with 7.1 digital audio, plus a 3-port USB hub for your keyboard, mouse and an additional USB peripheral device, this KVM switch is perfect for accessing two separate systems using the same workstation - ideal for server control, simplifying access to multiple computer systems.
  • Hassle-free operation
    This 2-port KVM delivers effortless operation through intuitive hotkey control, providing a simple yet comprehensive solution for switching between each connected computer. The KVM also supports manual operation using the easy-to-access toggle switch located on the front of the switch.
StarTech.com 2-port Mini DisplayPort KVM switch - USB 2.0 - 4K at 60Hz - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
USB powered, built-in 3-port USB 2.0 hub, 4K resolution support, 7.1 channel audio support, metal housing
17.7 cm x 8.2 cm x 2.5 cm
342 g
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
2 x DisplayPort input , 2 x USB 2.0 Type B , 3 x USB 2.0 Type A , 1 x DisplayPort output
2 x keyboard / mouse / video / audio cable - 1.2 m
DDC-2B, FCC, RoHS
17.7 cm
8.2 cm
2.5 cm
342 g
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
BGC0 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £7.46
BGC0 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £9.92
BGC0 StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £195.07
BGC0 StarTech.com 10 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.45
BGC0 StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.32
BGC0 StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £151.45
BGC0 StarTech.com DisplayPort USB KVM Switch In Stock £201.08
BGC0 StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £11.43
BGC0 StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £15.06
BGC0 StarTech.com 6ft mDP to HDMI cable - 4K In Stock £14.23
BGC0 StarTech.com 3ft mDP to HDMI cable - 4K In Stock £12.97
