StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter
Quicklinx: 7RPTWS00 Mfr#: ESATAPLT2LP
£6.73 ex VAT
£8.07 inc VAT
Add two eSATA ports to your PC, extended from internal Serial ATA connection ports. This 2-Port eSATA plate (low profile/half-height) adds external data support to any existing SATA (Serial ATA) controller, allowing you to connect external SATA (eSATA) storage to a computer. With support for data transfer rates of up to 300MBps, this external SATA plate enables you to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections. Connecting eSATA storage couldn't be simpler. Just install the plate into an open I/O low profile slot on your computer and connect the cables to the Serial ATA connectors on your motherboard or controller card. The slim SATA data cable connecting the motherboard or controller card SATA connection to ESATAPLT2LP is takes up minimal space inside the computer case, providing less clutter for increased internal airflow.
StarTech.com 2 Port Low Profile SATA to eSATA Plate Adapter - SATA internal to external panel - 30.5 cm
Interface Speed
Serial ATA 150/300/600
Low profile
Length
30.5 cm
Connector
7 pin external Serial ATA - male
Connector (Second End)
2 x 7 pin Serial ATA - female
Red
Storage Cable Type
Interface Speed
American Wire Gauge (AWG)
26
Low profile
Length
30.5 cm
Red
Connector
RoHS
Price Range Ex VAT: 0 - 50
