StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART
Quicklinx: 6PGGWS00 Mfr#: PEX2S952LP
Type: Serial adapter
Compatibility: PC, Unix
Interface: PCI Express x1
More than 50 in stock
£26.21 ex VAT
£31.45 inc VAT
The StarTech.com PEX2S952LP low profile/half-height PCI Express Serial Card turns a PCI Express slot into two RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, and ships with a low profile bracket installed but includes an optional full profile bracket that lets you add two serial ports to virtually any computer (regardless of the case form factor).
StarTech.com 2 Port Low Profile Native PCI Express Serial Card w/ 16950 - Serial adapter - PCI Express low profile - RS-232 - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
RS-232 x 2
2 cm x 9 cm x 8 cm
58 g
RS-232
Data Transfer Rate
460.8 Kbps
1 x OXPCIe952 - Oxford Semiconductor
Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Serial adapter
PCI Express x1
PCIe 1.0a
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
460.8 Kbps
Software flow control
Processor / Memory
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express x1
WHQL, FCC, RoHS
Software Included
Drivers & Utilities
2 cm
9 cm
8 cm
58 g
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
6PGG StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.84
6PGG StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
6PGG StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
6PGG StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
6PGG StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
6PGG StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 0 - 50
