The StarTech.com PEX2S952LP low profile/half-height PCI Express Serial Card turns a PCI Express slot into two RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, and ships with a low profile bracket installed but includes an optional full profile bracket that lets you add two serial ports to virtually any computer (regardless of the case form factor).
- StarTech.com Replaced by PEX2S953LP - 2 Port Low Profile Native PCI Express Serial Card w/ 16950 UART (PEX2S952LP) - serial adapter - PCIe - RS-232 x 2
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.0a
- Ports
- RS-232 x 2
- 2 cm x 9 cm x 8 cm
- 58 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460.8 Kbps
- Processor
- 1 x Oxford Semiconductor OXPCIe952
- System Requirements
- Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI Express x1
- PCIe 1.0a
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 460.8 Kbps
- Software flow control
Processor / Memory
- Processor
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express x1
- WHQL, FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 2 cm
- 9 cm
- 8 cm
- 58 g
- Limited warranty - lifetime
- -20 °C
- 85 °C
- 5 - 85%
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
