StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART
Quicklinx: 76T5WS00 Mfr#: PEX2S553LP
Type: Serial adapter
Compatibility: Mac, PC
Interface: PCI Express
  • Windows 8 (32/64 bits)
35 in stock
£26.21 ex VAT
£31.45 inc VAT
The PEX2S553LP low profile/half-height PCI Express serial card turns a PCI Express slot into two RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 serial adapter card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64-bit), Linux Kernel 2.6.11 and up, and ships with a low profile/half-height bracket installed but includes an optional full profile bracket that lets you add 2 serial ports to virtually any computer (regardless of the case form factor).
This product is a replacement for the PEX2S552LP card.
StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232 x 2
2 cm
63.5 g
Cabling Type
Serial RS-232
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4 - 10.7, Windows 8 (32/64 bits)
Serial adapter
PCI Express
Ports
RS-232 x 2
Wired
Cabling Type
Serial RS-232
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
WHQL, FCC
2 cm
63.5 g
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
76T5 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
76T5 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
76T5 StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
76T5 StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
76T5 StarTech.com 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART In Stock £28.89
76T5 StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART In Stock £27.31
76T5 StarTech.com 2S1P Native PCI Express Parallel Serial Combo Card with 16550 UART In Stock £22.25
76T5 StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART In Stock £26.21
76T5 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.25
76T5 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.14
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 0 - 50
