StarTech.com 2 Port Industrial USB to Serial RJ45 Adapter - Wallmount and DIN Rail
Quicklinx: 80H6WS00 Mfr#: ICUSB2322RJ
  • Windows 8 (32/64 bits)
Add two RS232 serial RJ45 connections to a PC or Server through USB, with this DIN Rail and wall-mountable adapter. The ICUSB2322RJ 2-Port Industrial USB to Serial RJ45 Adapter (Wallmount and DIN Rail) allows you to add two RS232 serial connections using RJ45 signaling ports to a PC or Server through a single USB 2.0 port. The RS232 to RJ45 adapter features COM port retention to maintain your port number assignments across a reboot and supports serial data rates up to 921 Kbps. The included DIN Rail clips (Top Hat) and wall-mounting brackets provide simple solutions for out of the way installations, while the sturdy metal enclosure offers durability in harsh industrial environments.
StarTech.com 2 Port Industrial USB to Serial RJ45 Adapter - Wallmount and DIN Rail - serial adapter
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 2
4.2 cm x 6.5 cm x 2 cm
78 g
RS-232
Data Transfer Rate
921.6 Kbps
Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Apple MacOS X 10.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 4.2 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Serial adapter
External
USB 2.0
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
USB powered, wall mountable, DIN rail mountable
2 x RS-232 - RJ-45
1 x USB 2.0 - 4 pin USB Type B
FCC, RoHS
4.2 cm
6.5 cm
2 cm
78 g
55 °C
5 - 95%
80H6 StarTech.com DB9 to RJ45 Modular Adapter - F/F In Stock £1.23
80H6 StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.85
80H6 StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £35.06
80H6 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £82.79
80H6 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £15.15
80H6 StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £32.95
