Add two RS232 serial RJ45 connections to a PC or Server through USB, with this DIN Rail and wall-mountable adapter. The ICUSB2322RJ 2-Port Industrial USB to Serial RJ45 Adapter (Wallmount and DIN Rail) allows you to add two RS232 serial connections using RJ45 signaling ports to a PC or Server through a single USB 2.0 port. The RS232 to RJ45 adapter features COM port retention to maintain your port number assignments across a reboot and supports serial data rates up to 921 Kbps. The included DIN Rail clips (Top Hat) and wall-mounting brackets provide simple solutions for out of the way installations, while the sturdy metal enclosure offers durability in harsh industrial environments.
- StarTech.com 2 Port Industrial USB to Serial RJ45 Adapter - Wallmount and DIN Rail - serial adapter - USB 2.0 - RS-232 x 2
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232 x 2
- 4.2 cm x 6.5 cm x 2 cm
- 78 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Apple MacOS X 10.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 4.2 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- Status Indicators
- Power
- USB powered, wall mountable, DIN rail mountable
- 2 x RS-232 - RJ-45
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- FCC, RoHS
- Black
- OS Required
- 4.2 cm
- 6.5 cm
- 2 cm
- 78 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com DB9 to RJ45 Modular Adapter - F/F | In Stock | £4.47 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £83.08 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.33 |
StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £49.60 |
